Footwell Lighting
22 replies to this topic
#1 JDM_TDCI
Posted 05 June 2017 - 04:45 AM
Can it be done on a Mk3 that doesn't have it?
Anyone attempted this mod?
#2 vindi93
  • 623 posts
Posted 06 June 2017 - 10:17 PM
I am about to do this if you look underneath the glove box might need remove a piece of cloth stuff you should find a connector taped up there are few posts around of people using the connector and a short piece of loom you have to get from ford.
#3 JDM_TDCI
Posted 06 June 2017 - 10:41 PM
Have you bought the loom from Ford? Guide price so i'm not stiffed when i go and ask.
  • 623 posts
Posted 07 June 2017 - 12:23 PM
Not yet i will keep you posted
#5 vindi93
  • 623 posts
Posted 07 June 2017 - 12:38 PM
I found this in another post elsewhere
BM5J=14F009 x 2 cost £15.00
#6 vindi93
  • 623 posts
Posted 10 June 2017 - 07:14 PM
Ok so after having hunt i found both connectors for the footwell lighting. Below is a pic of the drivers side one its curled back on itself
#7 vindi93
  • 623 posts
Posted 10 June 2017 - 07:18 PM
Having got the connectors free i plugged the footwell light i have and no light. Checked with volt meter no voltage on any of the pins whether the voltage will appear if the bcm config is changed to enable ambient lighting i dont know.
#8 JDM_TDCI
Posted 18 June 2017 - 10:55 AM
Did you have any luck with this?
#9 vindi93
  • 623 posts
Posted 18 June 2017 - 03:52 PM
Im still get use to the software at the moment, the lights didnt work when i just plugged them in lol
#10 JDM_TDCI
Posted 18 June 2017 - 04:43 PM
So did you activate it on the software and it still didn't work?
I haven't even looked into the software bit yet. Still waiting for bits to get delivered to give it a go.
#11 vindi93
  • 623 posts
Posted 18 June 2017 - 06:52 PM
I succesfully read the config i just havent booked up the courage to write to it yet lol
#12 vindi93
  • 623 posts
Posted 18 June 2017 - 08:06 PM
As you can see here
#13 JDM_TDCI
Posted 19 June 2017 - 05:40 AM
Ah i see.
From other threads/posts i must make sure to always save the current settings before adjusting stuff :D
#14 vindi93
  • 623 posts
Posted 28 June 2017 - 02:46 PM
Just wish i knew someone who had done it succesfully on the zs model
#15 Ldsundance
  • 5041 posts
Posted 28 June 2017 - 09:10 PM
you fine making small adjustments to the config it,s only when trying to update things like the ipc software that you can run into problems
#16 vindi93
  • 623 posts
Posted 30 June 2017 - 03:51 PM
You done anything on a mk3?
#17 Ldsundance
  • 5041 posts
Posted 04 July 2017 - 08:45 PM
i haven't done a lot as i have a lot of everything already fitted from factory like the ambient lighting, which i plan to extend to the rear doors, i have used focccus to add that i have a towbar and trailer module and changed the wheel sizes, i have also been playing with a spare instrument cluster changing/update the software to add twin trip computer but this can take a couple of hours (built my own loom to do it out of the car) and can cause a dead dash if you get an error at 99% when flashing, it is repairable but you have to start the process again, not good if you need the car, also been able to change the mileage at the moment i have been able to reduce the mileage once but increase a number of times, i have been doing this with information from focusfanatics, also the bcm is where the the info is read from the ipc is just a backup
#18 vindi93
  • 623 posts
Posted 05 July 2017 - 10:05 PM
I see the ipc is a backup, i wonder if the ipc automaticaly gets written too once you have written to the bcm.
#19 vindi93
  • 623 posts
Posted 30 July 2017 - 11:14 PM
ok update decided to go ahead and change the config using the focccus after making a backup twice lol.
changed the aesthetic lighting to "ambient lighting single colour". wrote to bcm ( with heart rate running on overload lol).
it got 100% and completed car returned to normal. powered off then on went into forscan and checked for any DTC codes on both buses. non reported disconnected forscan and powered on car all o.k .
reran focccus to see if that change had actually been written and it had.
BUT the footwell lights are still not working i tested the lights on a transformer and they work fine. so abit more digging is required.
maybe i need to check the bcm once i work out where it is located.
#20 vindi93
  • 623 posts
Posted 30 July 2017 - 11:28 PM
if you fancy looking at the wiring
