Auto Dimming Rear View Mirror
12 replies to this topic
#1 vindi93
Posted 29 December 2018 - 11:30 AM
I have an auto dimming mirror came out of an ST i also have the roof lining and loom is it possible to retrofit the mirror i can probably sort the wiring side its the physical side my mirror has an oblong fitting where the ST one is round.
#2 E TEA 66
  • 3979 posts
Posted 29 December 2018 - 03:33 PM
It may be doable although I have a feeling you would have to swap the bases over or the stem on the mirror which seems more feasible but can't be certain without seeing them both .
#3 Mike11
  • 14000 posts
Posted 29 December 2018 - 04:23 PM
When I fitted the Mondeo one into my ST170 I swapped the bases round too.
Posted 31 December 2018 - 03:12 PM
This is the mirror to go onPosted Image
Sent from my SM-G920F using Tapatalk
#5 vindi93
Posted 31 December 2018 - 03:55 PM
And this is the current mirror.Posted Image
#6 E TEA 66
  • 3979 posts
Posted 31 December 2018 - 04:43 PM
As Mike has stated it would look like you need to swap the bases over too unless you can change the stems then it would be easier .
#7 vindi93
Posted 31 December 2018 - 04:46 PM
By base i assume you the bit glued to the windscreen ?
#8 E TEA 66
  • 3979 posts
Posted 31 December 2018 - 05:00 PM
Yes mate that's right but you'll have to take good care doing it .
#9 vindi93
Posted 31 December 2018 - 05:02 PM
View PostE TEA 66, on 31 December 2018 - 05:00 PM, said:
Yes mate that's right .
Ok looking at it looks like i will need one of these
https://rover.ebay.c...tm/272379763252
Are they easy to get off windscreen ?
#10 E TEA 66
  • 3979 posts
Posted 31 December 2018 - 05:07 PM
I don't think Mike used one of those but if it saves damaging the windscreen then but just wait for Mike to reply with an explanation and take it from their mate .
#11 Mike11
  • 14000 posts
Posted 31 December 2018 - 05:55 PM
Not sure what that part is but if it is an adaptor to go between the stadard and your mirror I would have a go with it, removing the original can be hard depending how well it is attached. My original on the Mk1 came off easily, but when I stripped it and removed the auto dim one it broke the screen. But I did glue it on with some super strong stuff, lol.
It can be removed but you need to take time and be careful.
#12 vindi93
Posted 31 December 2018 - 06:04 PM
No its a replacement base to suit the mirror not an adaptor.
#13 Mike11
  • 14000 posts
Posted 31 December 2018 - 06:58 PM
Ah right. Might be worth finding some solvent dissolver and gently scraping your old one off. Then clean it up and fit the new one.
