Slight Jerking\miss Fire
22 replies to this topic
#1 Dennis the meance
Dennis the meance
  • 190 posts
  • Locationsouth normanton derbyshire
  • Car:2009 1.8tdci zetec s
Posted 12 April 2015 - 06:31 PM
Hi on my 2009 1.8tdci I have jerking miisfire type symptoms at 1700-1800 in any gear with throttle just pressed if you press pedal down you can drive through it once over or below these revs any ideas people ?
#2 Daz158
Daz158
  • 4803 posts
  • LocationBarnsley S74- Enjoying the Bluefin
Posted 12 April 2015 - 08:04 PM
I had a hesitation in my 1.8 tdci 2009 a few years back.  Had it in when under warranty and ford did a software update and it seemed to sort it out.  I now have bluefin and don't seem to have any problems like that.
#3 chudleighpaul
chudleighpaul
  • 432 posts
Posted 13 April 2015 - 01:13 PM
Injector problem, I had it, and the car shook quite badly when the engine was under load.
#4 Dennis the meance
Dennis the meance
  • 190 posts
Posted 13 April 2015 - 03:35 PM
Thanks guys some things to look into to get it sorted
#5 gt-keith
gt-keith
  • 156 posts
  • LocationWest yorks
  • Car:Ford Focus Mk2 Tdci 1.8 Ghia
Posted 17 April 2015 - 04:47 PM
Sticky EGR valve, put a can of BG244 in the tank and see what happens. :-D
#6 jbeer
jbeer
  • 3873 posts
  • LocationBirmingham
  • Car:BMW 320i M Sport
Posted 25 April 2015 - 09:02 AM
Also try using Wynns EGR Cleaner, it's an aerosol that sprays into the air intake…did it on mine and even though I was not having any problems it still helped make the car run smoother
#7 Dennis the meance
Dennis the meance
  • 190 posts
Posted 25 April 2015 - 05:44 PM
Cheers will give it ago got some bg244 on the way as well
#8 Dennis the meance
Dennis the meance
  • 190 posts
Posted 29 April 2015 - 10:46 PM
Got my bg244 do I stick it in near empty tank or a full tank ?
#9 jbeer
jbeer
  • 3873 posts
Posted 30 April 2015 - 05:53 AM
Add it to an empty tank, then add a full tank of fuel and away you go
#10 Dennis the meance
Dennis the meance
  • 190 posts
Posted 30 April 2015 - 06:36 AM
Thank you mate
#11 chudleighpaul
chudleighpaul
  • 432 posts
Posted 30 April 2015 - 11:19 PM
Don't mess about with snake oil products, get the injectors checked first.
#12 gt-keith
gt-keith
  • 156 posts
Posted 06 May 2015 - 04:54 PM
I've used BG244 in my 1.8 once a year with great success,  despite low milage in the winter months it runs as sweet as a nut. To refer to such a product as "snake oil" is a little harsh.
And it's a cheaper try than having the injectors checked out.
#13 JDM_TDCI
Posted 06 May 2015 - 04:59 PM
Sounds very similar to my problem.
Yet i had less replies to my thread???
It's a strange fault.
Just under 1/4 tank of fuel, 2000 revs, 50-70 mph in 4th or 5th and in stutters/judders like the car isn't getting fuel.
Change down to 3rd and floor it and all is well.
I fill up now at 1/4 of a tank and it doesn't happen.
Unsure what it could be.
#14 rob18
rob18
  • 3204 posts
  • LocationNewcastle
  • Car:Mk6 Fez ST & Mk1 C-Max
Posted 07 May 2015 - 02:24 PM
Sounds like fuel pump to me
#15 JDM_TDCI
Posted 07 May 2015 - 03:20 PM
Fuel pump has been tested and all was ok. Double checked by changing the fuel pump for a new one. Still occurred.
Weird fault really.
#16 rob18
rob18
  • 3204 posts
  • LocationNewcastle
Posted 07 May 2015 - 03:52 PM
Weird fault really.
Wow sounded exactly like a failing fuel pump >.< Can only imagine it's software related? Remap should cure it?
#17 Griff
Griff
  • 6978 posts
  • LocationSunderland
  • Car:1.8 Mk2.5 TDCI Titanium
Posted 07 May 2015 - 10:43 PM
My previous mk2.5 1.8 did similar.  Light throttle at around 1800 revs and the car stuttered a bit. . Seemed more noticeable in 3rd, but also had it in 5th too. Accelerate a bit more, and it was ok.
Took it back to the dealer many times, and they couldn't solve it.
#18 JDM_TDCI
Posted 10 May 2015 - 07:45 PM
Seems to be the case at the moment with this issue.
I'm getting down to just under a 1/4 of a tank of fuel now so i shall see if it happens again.
I don't mind paying to get it fixed i just want to know what it is!
#19 Dennis the meance
Dennis the meance
  • 190 posts
Posted 10 May 2015 - 07:55 PM
Mines at any state  of tank of fuel full low its there
#20 DazW
Posted 10 May 2015 - 08:01 PM
When was the last time the fuel filter was changed?
